Twist Engine Parts
I've got a Kawasaki X2 with a 750 put in it. I bought it second hand and the engine is made by a company called Twist. Anyone know where to get parts for these engines? I'm assuming it needs a new piston or crank, but haven't taken the cases apart yet. I thought it was the o ring and I fixed that, but the engine still doesn't fire up. Back cylinder has next to no compression. Many thanks for the help.
This could be very possible. In that case, how can I determine which replacement parts to order? Would it just be a Kawi 750 piston kit? Or are there variations within the 750 engine?
SUPERJET-113
GASKETS FOR CHAMP BRAP!
That is just a Twist head. Twist was a off shoot company for MSD back in the day. You just need a standard 750 piston kit/gaskets and the head has domes, but uses a standard OEM style head gasket.
