I am trying to get my superjet put together before the freeride and ran into a snag with one of my through hull cooling lines twisted off right at the bulkhead. I want to run dual cooling and don't want to replace the cooling line. The hull is setup for trim and each end of the trim is finished off with a barbed pipe fitting but I have no idea what was used to connect the two. I am worried that the PO may have just drilled a through hole and glued the fittings to the hull with the trim cable and there is nothing but a hole in the foam. I want to use it as a second cooling line but don't want to fill my hull, how likely is it that they didn't run some sort of tube?
