Trick Help!
Go4Pro!
Practice = #1
Pelican Lake MN
I need help with my power sub... and other tricks that are good to practice.. i took a leap on trying the power sub but i'm close but i'm not at the same time... i have watched every youtube video every made about power subs... and i still can't get it this is what i have so far.
1: Put left foot out of bucket
2: put foot in water and make really sharp turn(left) and fall into the turn
3: push down when making turn
4: (jet ski will ewant to tutrle) let it
5: ??
i don't know what to do after you make the turn, my jet ski always floats even with my kester on it... I ride a 1987 kawaski 650sx it is in perfect condition, very minimal hours, and i have been trying this trick for about 2 weeks now, and i haven't gotten anywhere. (but hurt) i need some help please, and i need some other steps for easier tricks, i can do the simple tricks like power slide, and make the big wake what thats all... nothing else, please help!
Ride: 1987 Kawaski 650sx
Glory_Freestyle
Old, but still ridin'!!!
On Step 2. Don't put your foot in the water. If you're turning to the left, put your front foot in the very front corner on the left side of the tray. If you're turning to the right, put your front foot in the very front corner of the right side of the tray.
On Step 3. Make sure you lean forward as you "push" the nose down into the turn. The bars should be in your gut as you go into the sub.
Step 5. When you and the ski are under, transition your body back to the center of the tray with your weight back so you can stabilize the ski and ride out.
left turn, left foot water, RIGHT FOOT FRONT MIDDLE-LEFT TRAY
Push Nose down hard, needs to go under before you give it more gas otherwise you will just slide along sideways
good instructional video unfortunatly cant understand waht he is saying but words mean nothin if you see pics
