I have one straight from DASA tho it seems a tad bit on the advanced side for pump gas.
Set static timing at 30 degrees btdc
Switch 3 s1=off s2=on s3=off s4= on to set static timing.Off to run.s5=on s6=on s7=off s8=on
Switch 2 s1 thru s4=off s5=off s6=on s7=off s8=off
Switch 1 s1=off s2=on s3=on s4=on s5=off s6 thru s8=on
retard begin speed=5000rpm
max speed rev limit=9000rpm
holeshot rev limit=3000rpm
max speed retard=2/17
max timing=max
timing can be reduced by changing s6 thru s8 configuration
This curve is not that aggressive for pump gas. I wouldn't be even close to scared of it......
I just feel like 30 static is a bit much. I'm no TL pro tho. Kinda new to it.
Here are curves I will be running this year on my ATP Flame TS2.
CPT 836 w/ +4mm light weight crank, w/ 48 Novis, ADA Head @185psi
Disclaimer, I've yet to run this curve, and am going on the advice of others.
Hope it helps
On my DASA 1200, switching from ATP curve to DASA curve made a significant increase in power
Red is DASA curve, blue is the curve it came with from ATPView attachment 328599
