cmg
Proud Dad!!
- Olympia, WA
I pulled my flywheel today on my 97' SJ to check my timing setting/stator and found a potential problem. First, there was a little oily liquid in the area below the flywheel. Second, the crankshaft oil seal behind the stator coil is starting to tear under the shaft.
Is the oily liquid from the crankshaft seal leaking? Is this going to be a big problem shortly. What should I do, replace the seal immediately?
