Who needs it to be bent? Cut the edges off and weld them on to make your 90Their setup is nice. I just couldnt justify the money when I had the materials there. I bought the saw on sale at harbor freight for 99 bucks measured and drilled two holes and then ground/cut a slot in for the blade to pass thru. Less than a hour of work and I had it up and running. Next up is to make a horizontal attachment for the saw.
Contemplated it, my tig is down right now and bending it would give me a nice transition. I may cut down the backside with an angle grinder on the bend line, bend in vise and run a bead on bottom side to keep the top smooth.Who needs it to be bent? Cut the edges off and weld them on to make your 90
I have version of that 10" press brake that came from Northern Hydraulics 20 yrs ago, still going strong.Wow,l like that little 10” press! Who has them
Do you have more specifics on the machine? Does it have an adjustable head? Is it a knee mill?Going to look at a small milling machine tomorrow. I have never owned a mill, much less used one, but have wanted one for a long time. Its about 400 lbs or so, trying to figure out how to get it from my truck onto the cart I had my lathe on. Guy says it includes tooling, any pointers on what to check for besides loose ways, spindle wobble etc?
Funny I'm in the process of making one of these right now for a 20 ton pressSpeaking of bending metal, I used my vise brake the other day to bend some 1/8” aluminum for my fuel jug rack. It worked, but was very close to the limit of my vise.
Does anyone have the 10” version for the hyd shop press?
jealous of your front porchWent from a 24’x40 workshop to this rental last August. Working on buying a lake house so hopefully we’ll close on one next week. First order of business is building a workshop that’s better then my last one.
How often do you guys with porta-band stands wish you had something with a wider throat? I'm starting to look at budget band saw options but am afraid I'll always be wishing I had something that can cut bigger pieces of plate. Otherwise who's got a larger metal bandsaw they recommend?
