w-nut
x2 nut
- christchurch new zealand
ive finally got enough parts together to build a new engine for this summer and wondering weather to get the cylinder ported or not . does proting effect the reliability much . i just cant decide what route to go . the new engine will be going in my x2 and will be a sxr 800 engine bored out to 840cc ported cases, rebuild crank with ceramic crank bearing, tbm non charging flywheel , wax ignition set up as a total loss, v force reeds duel 46mm carbs and a blaster limited chamber . i have all these bits already sitting in the garage ready to go but not sure weather to get the cylinder ported . i know the pro,s with porting but is there any cons with porting like shorter engine life etc etc .
any advice would be appreciated
thanks guys
thanks guys
