Cannibal
Tasty Human
- Summit Lake, WA
i was under the impression that there should only be enough resin to saturate the fibers. When i was glassing a sub box that molds to my trunk i used more resin then needed to saturate the fibers and it turned out super solid but brittle and very heavy. When i added a layer of glass to a wakeskate project im working on, i used a roller and soaked up any extra resin and it felt the same weight wise but was super flexible still.
You are correct. In fact there is an exact amount of resin needed to wet out x amount of cloth. People who make a profession out of this will calculate the amount of resin needed for that amount of cloth and use no more. You want the least amount of resin possible to get the job done.
