To girddell or not to gri dal ??!!
nikad58
1974 YZ 701
A bad week huh ?
Hummmmm is a extra $100.00 bucks worth the insurance ??
Blaster #2.. A lil grinding,sanding and JB Weld and it's as good as new !! (girdle's all the way !)
And SJ #3 busted a sleeve !!! can you weld it ?? haha ( never going to 84mm on a 61x again !)
Looks like the Whore is on the prowl
SUPERJET-113
GASKETS FOR CHAMP BRAP!
Non girdled heads are a thing of the past!
i say girdle anything non stock.. pipe, head, porting, etc. Just to be safe.
Gridal studs and acorn nuts for all the merry men I say!
Domes and orings and sillycone... lol
waxhead
wannabe backflipper
gold coast
You need a wooden head like this
its 100% pure rose wood
i know i know
it wooden work but it looks oh so cool
sjetrider
if you spend $2000.00 on a Lamey you could save the $100.00 on Girdal head, you wont need w/ Lamey its not gonna crack. How about just going Billett ADA bigbore? For $2200.00 they throw in a girdle head.
Y
yamaslut
Guest
waxhead said:
Thank god im a superjet boy
:Banane01: :Banane01: :Banane01:
damn.... John Denver made it all the way over there?
:cheer: :cheer:
Mouthfulloflake
ISJWTA member #2
NW Arkansas
Hey Nikad?
Did you really JB weld that cracked cylinder?
will it be ok with a Girdled head after that?
ive got one that is cracked as well, not that bad even, and I wanted to do that.
but feared it would get worse.
Did you stop drill the crackes or anything?
got photos of the repair?
Mouthfulloflake said:
Hey Nikad?
dont do it, dude! get it welded..... using the proper technique, which is having the cylinder sandwiched between the gridul head and cases and torqued properly. i would think drilling either ends of the crack wouldnt be a bad idea. then weld it, but just a second or 2 at a time, then mist it down then hit it with a wet rag to let it get touchable. while its time consuming, it keeps the cylinder from distorting from excessive heat in a concentrated area.
JB weld will work in a bind but i doubt itll last any signifigant amount of time on the engine.
nikad58
1974 YZ 701
Hey Nikad?
lol i missed that.. I was only kidding about the JB weld.. To me that crack is way to big to weld without having to do alot of mechine work after.. poof, in the trash
