- near beautiful bobcaygeon
Hello,
i have a single mikuni sbn 44 carb, 61x case and 61x cylinders, i have a factory b-pipe. idk for sure but i think the head and domes are like stock. I guess also i should mention that i have a lowered hood and so I think maybe the ski still has the stock air intake filter and cover / flame arrestor? (is this right?) Please see pic
Is this chart ok to use for pop pressure targets?
![IMG_2653[1].JPG IMG_2653[1].JPG](https://www.x-h2o.com/data/attachments/370/370302-020a462d4baceb7c4c482c9e4079bc85.jpg)
If the measured pressure for a given configuration needs to go up or down but i am using the suggested spring and the measure pressure is fairly close, then is trimming the springs the way to adjust the pop-off pressure? Does shortening the spring by trimming some off a small piece of spring then reduce the pop off pressure?
Am i at least barking up the right tree?
Can the resultant pressure be changed just by stretching the spring (to get a higher pressure) or compressing it down firmly to make is shorter (for a lower pressure) if so?
Any tips for this process?
Again, as always, the expertise and knowledge so freely shared here is very much appreciated.
