To all of those that view this post...
I don't post much here anymore from the lack of respect to others. (including being directed @me and @xscream)
ATB has bad settings, no one apparently understands his settings!
Do you see that he has Switch 1, S1 on and S5 on?
He is running a straight flat curve!
His Retard Begin Speed is set @ 9000 RPM's!
(with his Rev Limiter set @11,750!)
I'm not sure if he set his static at 30* or 27* degrees from reading his post.
But he does have the max timing set at -5, so he is running either 25* or 22* degrees for static.
ATB,
Use Christians_83 settings.
Set static @ 30* degrees with the following settings.
Switch 3
Retard begin speed. 5000 S1 off - S2 on - S3 off
Max speed rev limit. 9000 S5 on - S6 on - S7off - S8on
Switch 2
Holeshot (all off) S1 off - S2 off - S3 off - S4 off
Max speed retard. 29* S5 off - S6 on - S7 on - S8 on
Switch 1
Max timing (all on) S6 on - S7 on - S8 on
Max/Min Revlimit S1 off
Max Retard/Max retard + 15* S2 on
Elec start S3 on
Start retard S4 on
Retard begin RPM +4000 S5 off
Chuck 'SUPERTUNE' Quenzler III
Xscream
