- Vancouver, WA
For those that want to use a 61X Factory B pipe or any other 61X exhaust on a 760 (64U) or 701 (62T) cylinder Time Sert is the ticket. The 62T or 64U cylinders use 10mm x 1.25 thread bolts. The 61X uses 8mm x 1.25 bolts so the exhaust manifold holes are smaller on the 61X.
The 8mm 1.25 time serts thread directly into the 10mm 1.25 bolt holes. You do need to use the counter sink tool to drill out the edges of the bolt holes. Use the insert tool to lock in the tine serts.
