- California
So I'm getting some weird vibes when I pin it on my 650sx, but nothing when I'm cruising around slow. I'm trying to figure out if its the pump bearings or the thru-hull driveshaft bearing. At idle, you can hear a rattling noise when its on the trailer, but both my buddies 650's do the same thing so I'm not sure if its normal or if we all need bearings ha. Also, I pulled the motor the other day to replace a cracked magnet on the flywheel, and I noticed that my drive shaft slides thru the driveshaft bearing with ease, but there isn't any side to side play, it doesn't leak, and I don't get any cavitation when launching from he beach. Any help here? Thanks
