Super Jet Throttle lever help
I have rick roy riser bars and bought a used UMI throttle lever that when I tighten it down it is still loose on the bars. Are there different sizes of bars or is the throttle lever not right?
Tuscaloosa, AL
you could also get a small strip of rubber and place between the lever and the bars...... Will fill the gap and the rubber will keep it from moving also.
