this ones got me stumped. Any ideas guys??????
generally, ski runs great, heaps of power everywhere.
but, if i slow down to a speed where i can just balance the ski and not tip over, i hear all these random deep pops from the engine, its not a smooth bbbrrrrrrrrr its more like bbbrrrr pop brrrr pop pop bbbrrrr pop brrr.
if i do this for a minute and grab the throttle it jumps out of the water and takes off, no hesitation or bog.
if i slowly up the revs, it "pops and brrrss" all the way up to the mid range and then clears up.
i can ride it round all day working the throttle flawlessly, but everytime i try to hold a constant speed, it sounds like crap.
its basically a new engine.
62t ported epoxied case.
61x cyl @ 82mm.
new B limited, screws: top 3/4, middle closed, bottom closed.
v force reeds.
lightened stock flywheel
stock ign.
ada head 180psi even.
stock 38s 72.5p 135m 115g springs.
so far, my trouble shooting has been:
different carbs: 38s, 44s, single riva PB, back to 38s all jetting / pop off combinations on all carb configurations.
checked reeds at each carb change always good.
new charge coil and lighting coil on stator.
changed cdi 3 times: stock to a mates msd back to different stock one.
3 coils.
countless compression tests.
countless plug changes always perfect dark tan colour br8es-11 Gapped to .70
countless pipe header screw changes (brand new full pipe today as well)
fuel mix is 40-1 castrol power tts full synthetic, 98 RON.
forgot to mention, sounds crisp and smoothe on the trailer when reving.
thanks in advance!
61x cyl @ 82mm.
v force reeds.
stock ign.
3 coils.
thanks in advance!
