- Northwest, CT
Ski need more tuning and flowvalve installed
HULL
-Rebuilt bottom deck, widened to tubbies, rockered to front bond rail, and custom shaped chines (supposed to mock the bottom deck of an EME Q8)
-Tom21 tubbies
-Flatdecked
-Full front and side carbon fiber reinforcement
-Removed all stock bottom fiberglass from front motor mounts forward
-Wrapped carbon fiber hood, with full internal carbon reinforcement and functioning cowl induction
-custom azhiaziam decal and reg. numbers by Craig Winsor
MOTOR
-Group K 850 sleeper bored to 84.5mm
-R&D intake manifold ported to 48mm
-V force 2/Mototasinarri reed system
-ProK flame arresstors
-stock sxr head shaved
-ADA billet couplers
-Crank Works rebuilt balanced and welded sxr crank
EXHAUST
-Factory pipe sxr wetpipe system, ported
-ATP waterbox
-Votionspeed couplers and t-bolt clamps
-2" PVC out the right footwell
-2" scupper to Versaplug from under bearing carrier out the right footwell (FLUSH to the bottom of the hull! And you said I couldn't do it)![]()
IGNITION
-Tbm lightweight non-charging flywheel
-Advent T3 with Jetworks custom curve set
-JSS upgraded coil
-removed and rewired all unneeded electronics from ebox
-Shorai lithium ion carbon/composite battery (1.6 lbs)
-JSS battery cables
FUEL
-Dual Novi 48's
-fuellines.biz lines
-Comet kart 2 gallon tank
STEERING
-Rebuilt Accusteer with stainless bearings
-custom made extra long quicksteer arm
-stock sxr cable with heim joints on both ends
-Pro taper xr50 expert bars
PUMP/TRIM/INTAKE
-rebuilt Sxr pump
-Epic freestyle pump cone
-Impros Solas dynafly 13/22 cut back 5mm
-complete Sato engineering sxr uptrim kit (25 degrees out of the box, with 30mm longer steering nozzle)
-custom R&D toploader intake grate
-stock x2 driveshaft
RANDOM
-Blowsion finger throttle
-Blowsion 45 degree pissers
-custom turf by Keith
-removal of any and all things adding unnecessary weight
-fuellines.biz fast flow cooling lines
-Dakine x-lace foot straps
Is there a big difference between an X-2 and like a 650? They look like they have a seat (that no one uses), and no movable handle pole, otherwise are they like a stand up?
The 650sx is a dork.
