Well i got the motor pulled heads pulled and cylinders pulled and the damage may not be as bad as i thought but its not pretty. Ive got some pics ill upload later but from my point of view (which is completly inexperienced in engines) it looks like the rod bearing on one of the rods blew out and there are peices below the crank and above the piston but no scratches on the cylinders at all. One of the tops of the pistons is a little eaten up as well as the dome but if its only some dings and dents should i worry about it?
Also how do i get the crank and rods apart? One rod seems to be ok but i cant tell because the other wont allow the crank to move very far.
Any idea what would cuase rod bearing to go out? id hate to rebuild and have it happen again.
Also tearing down a motor is much more simple then i thought it would be. Lets just hope i can rebuild it as well
