TBM w/ Mag Prop set up in SJ.
waxhead
wannabe backflipper
gold coast
i have a tbm cone and a magnum prop in my ski
it works killer my ski is not limited and so it can drive it well
i think if you were limited you would want to make sure you have a low prop in it
Scorn800
Ride for life
North NJ
The TBM pump cones put a hugh load on the motor. It will pull your rpms lower. So you much have the right pitch prop to keep your motor spining the rpms it should.
I know with my limited sxr I was pulling 7380 without cone and 6990 with.
When pullin your rpms lower you must jet right or you'll have some nice burnt pistons.
