- Grand Rapids, MI
Yeah......I don't think your primer line caused that lean condition and blew your motor....You might want to figure out the real reason.
I also would suggest Team Scream.
If your not afraid of work, get the cases split and just bring the top end and the crank and we can check thing out and we MUST find the reason WHY your engine did this before we can rebuild it.
Call Or come by shop...Chuck
I took the carb apart and everything seems fine besides the "round pump diaphragm" thing on the needle/seat side of carb.
Can a defective pump diaphragm cause the engine to run lean??
I have insurance on my jetski thru progressive.........do insurance companies typically cover blown motors??? my buddy blew the motor in his Jet Boat and his insurance covered it.....that is why I ask??
Prior to it blowing I drove it around and it would die once and a while after I would open it up and then let off the throttle.......sorta bog down then die..........which I assume is a result of the leak in fuel line.
