synchronizing carbs
WaveDemon
Not Dead - Notable Member
Hell, Florida
you guys dont even know what cfm means(cubic feet per min.)
i need some real motor heads in this thead. cause you guy are beat me up over something that you guys with duel carbs are missing. your cyl are not running the same. thats why you synch them.
why do I need cubes or feet in my carb, my shyt is so fast they measure it in milliseconds. keep you dog azz slow minute carbs to yourself!!!! :party:
WaveDemon
Hell, Florida
you can do that but not everyone has a flow bench to use theres other ways
im done with this topic. im out later
are you talking about one of these?
good luck getting a patent.
#ZERO
Beach Bum
Florida - U.S.A.
Are you using the Jim Beam Velocity Pressure Manometers for your carb synchronization method? :trink26:
If one synchronized swimmer drowns, the rest have to drown too.
WaveDemon
Hell, Florida
it measures the vacuum drawn by each carb. you put it on the opening of the carb and the little ball floats up the meter. then you adjust both carbs until they're the same. they come with directions.
Wolf Child
Just Another Octard
All over C. FL
ok, to be clear...
Yes. synch your multi carb set-ups.
Yes. you will notice a difference
Yes. your engine will run better
No. you cant do them with them off the motor
Yes. there are plenty of DIY carb synch tools on the market
Yes. bigdog is smoking crack if he thinks he's gaining 20hp just by synching his carbs
I hope this answered everyones questions.
We now return you to your regularly scheduled doofus fest
he didn't say 20hp.he said 20% and seeing that his motor probably makes about 300hp,that comes out to about 60 beans or so!:spank:
you guys are crazy my ski has some much bottom end. i put my motor against your strokers anyday. with stock bore 701, porting by me always, and 240 psi compression with duel 44s with v force cages and reeds. i had a lamey motor and thats was my starting point in all this but i knew there was a cheeper way so i made my own pipe and use factory pipe manifods. you guy just buy off the self stuff. and have what everyone one else has. people just need to look outside the box sometime. im a fabricator i build my own stuff. i still use yamaha platform 62x case with 61x cyl. i have friends with cnc machines and ever other tool i need. i believe im making close to 130 hp on the low side. but im always on a buget and i dont have a lot of money to buy all this cool stuff so i have to make it. i bet there is a lot of people on this site just like me. trying to do the best they can with the money the have.
