- Annville Pa
Has anyone found the Factory Pipe jetting to be to lean? I just installed wetpipe with 80 Lows 3/4 turn out and 152.5 highs 5/8 turn out and it is lean on the top end. Mainly just the rear cylinder I actually stuck a ring on it . It shows good color on the front lean on the rear. Motor is stock internals just groupk cut head and Jetenetics flywheel. What are you running for jetting? Any help would be greatly appreciated.
