- MICHIGAN
Did you switch the waterbox to the opposite side? Got any pics of how you have it setup?
Sent from my DROID BIONIC using Tapatalk
You still have this hood. Im interested in buying it.
Did u remove the foam in the nose when u put the waterbox there?
I have a triple in my SXR. I just figured since I'm getting a good deal on an SXI pro hull that just needs a motor, my limited motor would be a perfect candidate. I may put a triple motor in it just for kicks but I doubt it.
I'm not running a waterbox with mine. There is no way to run nose foam, a waterbox and a stock tank. You have to remove the stock foam and shift the tank slightly right to get the pipe to fit.
Its ok to run without a waterbox? I wana do this setup but not quite understanding what you did. Is it ok to place a waterbox in the nose in front if the gas tank or no?
I'm not running a waterbox and it works fine, I would like to compare with/without waterbox, but I have been very happy with my setup. All the water box does is dampen sound and provide a little back pressure, my idea on running the long silicone hose was to absorb sound and the length itself provides more pressure along with the inline resinator. Its way quieter and less obnoxious than when i ran the coffman rocket mod pipe! If your going to run a water box you need a rn superjet box and tank.
I think an SXR tank would fit with either an SXR or SJ box up front. Ill have to wait til the hull shows up here and test fit all the components seeing as I have an extra SXR box and tank and all the necessary tubing.
If not I will be in the market for a silencer/resonator.
Is it ok if the waterbox touches the gas tank or is that bad?
