SXR 800 limited with factory dry pipe- Could someone explain the routing for adding another cooling line.. Where does the extra line go in the motor and how many lines should be coming of the head...
you tap into the side of the pump, you can use the pisser tube from the stock exhaust to get the water into the engine compartment. Tap a second line into the manifold. 2nd line out of the head overboard.
Or
you can run split cooling.....
1st circuit - into manifold, out of head (2 lines) overboard
2nd circuit - into pipe then overboard.
I have a extra line in the manifold and an extra line coming of the head.. but the ski has no power, to ? to much water in engine?? ski run great with only 1 cooling line.
its pretty hot but when you throw some water on the engine and pipe it does not sizzle.. I have been riding it like this for two years but Lm not sure if it would benifit me to run 2 cooling lines or not.
