- Taupo NZ
Currently finishing up a WDK Rok with a stock SXR motor, exhaust and pump. It has two 3/8in lines running from the pump (already drilled and tapped pump for a second 1/4npt x3/8 90deg).
I want to run the cooling in the image below (taken from an X-2 thread on PWC today). My question is, the SXR has one fitting on the manifold, not two (green lines "from pump" in the image). Will I get enough flow going to the cylinders/head with one line inlet or do I need the two to run it this way. Don't want to overheat anything.
I'd rather not have to drill and tap the manifold for two fittings if I don't have to.
