650/X-2 sx carb on an x2
Hey guys, just wondering if there is an easy way to swap an sx Carb onto an x2. I was thinking of using an sx cable and bracket.... lemme know what y'all have come up with. Thanks
dfw
You will need to use the SX cable and bracket. Just loop the cable over the tank between the hull and battery. Glue some rubber wherever the cable touches to keep it from chaffing. The longer cable wont feel as crisp but will work just fine.
Vumad
Super Hero, with a cape!
St. Pete, FL
I am running a cable from a '94 XI SS. I have a R&D 750 intake manifold which has a mount on the manifold, and one of those disc that let you put the cable any place you like on the disk. Has been working just fine. My 650sx used a bracket that connected to the motor mount. The XISS cable would be too short for that attachment placing. I know a bit less about the carb options with the 650, mine came with an aftermarket set up witht he motor mount pull I described.
