Blaster swaping 701cc to 760cc
australia
hi new here to the site, tried searching for it but couldnt find anything. im thinking of buying a 760 motor and doing some work to it and putting it in my blaster. Would i have to change my eletrics to do this and what other problems my arise
thanks in advance
junkyardj
┌∩┐(◣_◢)┌∩┐
dont think you'll have any problems with your current electrics but remember that just because its more cc's doen not mean it'll hit harder
the port timing sucks on oem 760's imo unless you do alot of work
australia
thanks mate yeah was going to do porting nad such i want to get another motor that way there is minimal down time while building it just thought i would do the work to a 760 instead
OCD Solutions
Rentz, GA
Done right the ported 760's can deliver some great power, the problem is, most aren't done right or not matched up to the right components so there's lots of bad press on them. I have a 62T 760 cylinder race ported by TLR ( Todd Lachance Racing) and I love the power from it. It is more torquey than revvy and has a long smooth powerband that just keeps pulling right off idle all the way to the top. Great power for surf riding as it always seems to be in the power at any rev and is smooth and predictable. Tons of power, just not on/off like the 61x can be.
I run an X-scream SS865 in the surf now and have no problem dropping back onto the 760 for a day. The power curve on the 760 is similar in how linear it is, just not as powerful.
That being said, if you do mostly flatwater and want that tear your arms out of the sockets power then you may want to start with the 61x based setup. They can produce violent hp for less money usually and are the most common configuration, therefore the most parts are available and at better prices.
Your electrics will swap right over with no problems as long as you swap all the components including stator, flywheel and ebox.
australia
ok thanks mate yeah it dose a surf and flat water. this is my first jetski was just considering the options of the 760 to see if its worth it
LBE
Eddie Would Go.
Charlotte, NC
I think a 760 conversion works better in the B1 than in a SJ. The higher port timing works better with a heavier boat that planes quickly. This is all personal opinion though. Just a pipe will wake up a stock motor quite a bit.
Lot of us cheap surf sluts down here run what we call the Puerto Rican big bore package in the surf.
760 62T cylinder
reeds
enhancer
advance the timing a few degrees
200 compression
lots of oil
and yes this is doable on pump gas wit PROPER jetting, verifying squish and common sense throttle duration - which in the surf really isn't an issue.
Like OCD said , it's all about matching the pieces... Proper impeller and nozzle bore helps unload the motor a bit to get past that port timing issue.
The T castings are much beefier so you can get away without a girdled head and don't have to bore your cases.
Remember the exhaust bolts are 10mm so you have to use inserts to drop to 8mm.
Ghetto = heli- coils
Properly = Keenserts
Is it the correct way to set up a motor - Hell NO ( hence our naming of it) and we can probably see Chucky shaking his head right about now - LoL
But its an alternative for a motor that probably will not live long anyways due to repeated saltwater douching -even though some of us have way more hours on ours than we deserve!
D-Roc
I forgot!
thats what i was thinking about your setup, it is exactly the way i would do it but with a TL for the bottom end power. Probably give great throttle responce and pull longer than the 61x 753cc. I ran a 735cc and it hit very hard but only for a few seconds and then its over. I would have loved to try the 760 62t cylinder in my setup. (for flatwater)
