superjet wet foam!!:(
ok just cut out old hacked up footholds on my 07 superjet.the foam is def wet,when i push on it water bubbles up.is there any way to dry it out.or i need to re foam??im putting the bob kit in so a good chunk of the tray is already out!what u guys think??
Iowa
Get the wet chit out (all of it even the stuff thats not wet) and replace with foam that doesnt absorb water and add hull drain to rear of ski
do a search there's plenty of threads like this one
Roseand
The Weaponizer
Wisconsin
Pink home depot insulation foam. Do a search on here for 'foam' and you should find more info.. It's been covered quite a few times for sure. Good luck! Defoaming sucks.
Sent from my XT907 using Tapatalk
Roseand
The Weaponizer
Wisconsin
I used the typical plastic drain plugs you find on most sit downs on my ski rather than the small metal plugs people were using. I got the pair for 9$ from JetManiac, include stainless screws.
Roseand
The Weaponizer
Wisconsin
Plugs
Foam
. ok do i plug these 2 holes in side on the firewall before refoaming?they have a white sticker seems like they would let alot of water in.but im gonna be running the drain plugs so does it even matter?
Roseand
The Weaponizer
Wisconsin
1/2 pvc tube, route it just like the steering cable tube(the black one in your pic).
You can use a heat gun to bend the tube like the stock one.
Roseand
The Weaponizer
Wisconsin
No, I did mine on the opposite side. You can do it above the steering one if you want to. I just decided to go the opposite.
It's the white tube on the left.
whatever is easier,do the trim systems pull from either side or the left?and what i pm jetmaniac about the drain plugs or they have a website,maybe its the skiclinic?
Roseand
The Weaponizer
Wisconsin
PM the user Jetmaniac.
Left side will be easier to seal and get a heat gun to bend it around.
I believe they usually pull from the left.
ok i just ordered new drain plugs off ebay for $9 they looked like yours in the pic,ill get some foam and should have this bad baby glassed up by next weekend ill post some more pics or start a build thread im probably gonna just paint the ski up for the hell of it we'll see.unless it gets hot as a mofo out then im just gonna start riding
just a thought, how many boards and what size of the foam did u need to do yours?
