Super Jet Superjet throttle cable
OCD Solutions
Rentz, GA
X2 on the Jetmaniac cable but be aware that the throttle lever end is bigger than the Yamaha cable. If you already have an aftermarket throttle with an adapter then you can remove the adapter, if you have a stock throttle still, it can be drilled and tapped larger to accept the Kawi cable or you can use the money you saved to finally buy an aftermarket throttle.
