SuperJet Surf Build
This is surf build. Purchased bare painted hull from JetManic.
Has been in small surf four or five times and fresh water lake only. Never ran in Halifax river which is death to all metals.
Very clean, hull bottom looks brand new.
Has paint chip on nose and did have front exhaust but removed before reinforcing.
Have more pictures.
Fully Reinforced Hull (Bond Line Filled, Blowsion kit with carbon laided over)
Tubbie Ones
Wamiltons Lowered Hood (does have a repair on top side)
Lowered Nose Piece was purchased on the X, never installed. Looks custom made seller said it was from JetManic.
X-Metal Pole -2 & Bracket (Used from Jet Maniac)
X-Metal Steering
Blowsion Trim (Old School from 04')
Bilge switch start/stop bracket
Dual 500 bilge pumps
Footholds
Dual cooling (Only using single / second plugged)
Skat Trak 12/17 Freestyle Mod Cut
Worx 201 Intake Grate
Worx Dominator Plate
61X Stock Bore with 44mm
Carbon Tech Reeds
MSD Ignition Enhancer
Factory B Pipe
Jetworks Flow Control Valve
ADA Girdled Head 185 psi
Stock Lightened #ZERO Flywheel
Kenny keepers
ADA Drive Couplers uses Kawi Damper
Also Included:
Carbon Fiber D cut ride plate
Stainless Ratchet Strap not installed (From JetManic)
Rolling Stand (seen in pics)
PVC Beach Cart (tires usable but leak slow from age)
Others spares like engine mounts, bendix, starter, bolts, etc.
1 1/2 old daughter is making me sell. Not interested in trades. $5600, In Ormond Beach Florida just north of Daytona. Thanks.
20200429_135212-small.jpg20200429_105938_HDR - small.jpg20200429_110041 - small.jpg20200429_110018_HDR - small.jpg20200429_105746 - small.jpg20200429_105738_HDR - small.jpg20200429_105808_HDR - small.jpg20200430_183053 - small.jpg20200429_105857 - small.jpg
