ColdFusion
I Am Canadian!
- Victoria, BC Canada
Hey All,
So last time I rode it (a few months ago) it started and ran fine. When I finished my ride I put it back on the trailer and went to fire it up to clear out the water....only clicks from the electrical box....nothing from the starter motor.
At the time I thought it was just a dead battery so I didn't investigate any further.
Well I put in a fresh battery yesterday and it tried to turn over once and then just clicks again from the electrical box.
I haven't had much time to investigate yet, so I thought I'd post this and get some other opinions/ideas before I do.
THINGS I NOTICED:
1) If I leave it for a few hours and try again it does try and kick over then starter stops. After that....just clicks from the electrical box
2) I opened the fuse access cap on the electrical box and there was moisture in there. The fuse itself was boane dry....but water ain't good!
3) plugs out...driveshaft spins....so it ain't seized
THINGS I THINK IT MIGHT BE:
1) dead or almost dead starter (that will suck to replace)...will try and bang it with a hammer in case there is a dead spot
2) dead solenoid (starter relay).....will test by briding with a screwdriver
I should also mention it has an MSD ignition enhancer....and I've heard they can go .
So...any ideas? anything to add?
Thanks in advance
Cheers
THINGS I NOTICED:
Thanks in advance
Cheers
