Super Jet Superjet starter problem's
I just finished putting back together my 94 Superjet and i thought i had wired it right. I hit the start button it starts fine, But the starter wont shut off until i disconect the negative off the battery. I tryed switching the two positives cables going to the starter relay and the same thing happened. Could it be a toast starter relay??
Rule out a sticking start button by disconnecting brown n red connector at ebox...then take needle nose plyers and touch both contact points on ebox side which will bypass start button n connect relay for juice to starter.
