SuperJet Speedwerx Dry Pipe - $750 USD Shipped
I hate to do it and I really don't want to do it but it has been sitting on the shelf for too long. It's my race version Speedwerx dry pipe for the 701. The original manifold spigot on the pipe broke off because of the misalignment from the original mounting bracket holes being muffed up from Speedwerx, it was a common issue back then, so I turned a new spigot out of billet 6061 aluminum on the lathe and had it professionally welded on. I also had the misaligned mounting bracket holes fill welded so you can align it properly and set the holes up exactly as you need them to be instead of putting faith in the original holes that were poorly slotted as I received it.
The other mounting bracket needed a crack to be touched up at inner corner of the channel form. There's also supposed to be 2 o-ring grooves but for added strength I opted to use the second groove as a welding trench. This should insure the spigot never breaks off again and the o-rings aren't for sealing, they're only for cushioning the movement when bouncing around in the waves. It's a complete ready to setup system other than the waterbox coupler which I think is the same as the b pipe coupler and the water lines are up to you. It has a Riva manifold with one water inlet bung fill welded because the original threads were in rough shape. It came to me this way and I don't like to leave anything in questionable condition so it's not an issue anymore. I had full intentions of running this again but suddenly over the last 2 years my group all got old and busy so we don't get out anymore, the p*ssing match is over so it's time to move on to other things and just accept what I have setup now lol.
There are 2 heavy duty couplers even though only one is in the pic and all nedded hardware is included. The head plate with the 2 lord mounts is not the original one, I made that one but I believe you can still get them if you want it. There are 2 red headed bolts that have fitted washers for the slotted holes on the manifold so you don't damage the slots with one washer riding the edge cutting into the manifold. All I need is to find a good enough box to ship it so shipping info might be a few days before I can get it out after purchase.
$750 usd shipped anywhere in the U.S. or Canada, if shipping isn't too far off of U.S. international costs then I'll be willing to ship to Australia too...sad day that I'm posting this but if you're looking for a unicorn here it is.
