Superjet sbn 44 broken screw help!
IMG_3184.JPG IMG_3183.JPG Got myself a used carb a while back on eBay and just pulled it apart to clean and rebuild it.
If you zoom in on the top left inside the carb you can see what is left of the broken screw.
oooooo thats bad. Best luck it to use one of those screw removers. But all that rust makes me thing that youll need to soak it in penetrating oil for a week to have even a hope of getting it out
blasterdude
Waiting for the ice to thaw!!!!
The Region
Best of luck man, I had the little screw bust off that holds the float arm down. After a attempt to drill out what was left the carb became junk.
