Ok first off 96 SJ with a bog standard engine.
Last weekend I was riding in the surf when the ski started to misfire really bad. I noticed when starting it I would get electric shocked through the throttle lever. I thought it looked like a damaged ignition lead as one of mine was broken (had been for ages) and seemed to have finally given up.
So I replaced the leads with Champion ones and it seemed to run ok right after replacing (on the trailer). However later on in the week it started running really badly, missing when it was revved. I fiddled wih all sorts of things fuel related and changed the plugs (B7HS) and seemed to get it running ok (I had also had the tank out and thought I may have pinched a fuel line).
Took it out today and all was not well. It seemed to miss worse once I had let it idle and then revved it. It would cough and splutter and sometimes die. By 'pumping' the throttle it came back and I could continue to ride. But basically it got worse to the point where it was unrideable and I gave up. I did notice that standing next to the ski (in the water) with my hand on the tray I got shocked when I pushed the start button.
Came home and checked everything. Took the carbies apart and cleaned them, checked the reeds were ok. No luck.
Could it be the new leads, or using B7HS not BR7HS (I have always used the non resistor plugs). Or was the initial problem not the leads?
Any suggestions? Or any troubleshooting ideas?
Cheers
Andrew
Cheers
Andrew
