X race ski, has some good freestyle potential though assuming that's the direction you want to take. Those front sponsons are alright, but if you want it to hook up in the corners look into some tubbies.
For now just ditch the hull extensions and get some footholds and you'll be set.
I see a trim lever. Is that a drop nozzle? If it is, look into turning it into a freestyle trim (nozzle goes up instead of down) or just do away with it altogether.
Look into getting a stock rideplate for it too. That worx will keep the nose planted. Over time, you'll learn how to use riding position to keep the nose down, but still allow it to come up when you need it to.
