manu
Clearwater, FL
- Clearwater, FL
I am trying to remove the stock impeller from my 05 Superjet. I tried to heat the impeller with a torch, and using an adjustable wrench but the impeller won't move!! It tried both way hitting the adjustable wrench with a hammer, and now I don't know what to do !
I went to Lowes and Home Depot with my pump to try to boxed wrench that will fit the impeller but nothing is big enough
Do you know what wrench size do I need, so I can order it on the web. Also wich way should I turn to remove the impeller, red or blue arrow ?
Please help, give me any advice you have.
Thanks
Thanks
