Superjet getting Shocked /Voltage thru Handlebars!?
Europa
My coil was broken, the spark went over trottle cable to handlebar. Thats where i get shocked.
Turn light Out, and Check.
Gesendet von meinem iPhone mit Tapatalk
rubbertoe
X-H20 certified
San Diego
Get a used coil from jetmainiac or OCD and start a process of elimination . You might not see where your problem is by just turning the lights off . It might take vibration and water to cause the short . But at least you have some areas to start focus on .good luck
RoscoeJ
760 B1
NJ/PA
Update:getting shocked, found the problem ,it was the main ground screw loose, in the ebox, ,tightened retested , no shocks the back of the ebox is aluminum
