Super Jet superjet engine
Hello all, I'm new to the form and wanna ask some questions regarding the flywheel installation. I've a minimum knowledge about the engine, I just let the mechanic do the job but just curious about the flywheel and pickup plate (I use MSD total loss system) installations, Do I've to put the red loctiteglue on the screw everytime to secure the bolts. I've a 760 motor with 85 MM pistons and the engine seems to be shaking a lot when idle so I'm afraid that either the pick up plate or the flywheel will come lose. I'm in th process of re-installing my engine so I'd like to get as much info as possible to make sure it'll run good.Please advise
Thank you all for your responses. I'm going to change from the MSD to the ATP Flame and want to make it as perfect as I can. I've read in some posts that Mr.Matt is using the flame system right now. Any recommendation for setting up the Flame system would be very much appreciated.
The Flame system will come with a very good set of instructions, with plenty of photographs. Can't go wrong there.
Hi Matt did u install the handle bar switch also?may i ask how to do it? I just received the package and will insatll it next 2 weeks as my boat is in the process of having a new paint job. I forgoit to order the optional lead wire for connecting the brain with the laptop so am I unable to change the curve myself?
You need the programming lead to change curves. I highly recommend you get that lead.
I personally do not run the switch to change curves while riding. I see no need for it - my motor is set up for one power output, I don't want to cripple it with a weaker curve.
