Superjet aftermarket plans
Mark44
Katie's Boss
100% one place
Intake grate worx 201 B pipe shave your oem head for now and ride the ski. No need for a pole at this point shorten the stocker if you like and your stock steering system and nozzle is just fine.
Mark44
waxhead
wannabe backflipper
gold coast
pipe, head, msd and a rejet it will set you up well. This will make a good reliable setup that will run forever. If you want more then look at porting.
An intake grate is a must
R
ridethelip
Guest
Modify the stock steering learn to ride it that way then if you just can't get the hang of it trade it for a car or sell it for more than it's worth so you can plot to steal nuclear warheads and rule the world
stanton
High on jetskis.
atascadero,ca
Alrite so i have about $2000 to spend on mods for my almost stock superjet. It has a solas prop and dual bilge. My friend just got a sweet setup with b-pipe, head, prop, and reeds. i also have holds and turf. I need a better set up. I WANT POWER :) Help me out please.
Here is my plan,
ADA Head Used from jetmaniac
B-pipe NEW
carbon Reeds
Pump cone
Intake scoop grate
Throttle lever
UMI Handle bars
Xmetal trim
Cylinder port job
How is this set up? I just feel that this still isnt enough power. i want to land rolls of boat wakes etc. And some freestyle. Maybe even a backflip off wake.
sounds good but skip the reeds, pump cone(unless you feel your impeller may be pitched a bit tall), and trim. get steering throw if you want to roll.
