Hi Guys,
New to stand-ups but not PWCs and just bought a SN 650. The ski has me pulling out my hair with the issues it has. The latest is that it never started easily when stopped in the water. I need to crank for a while and play with the throttle or let it sit for 15Min. It seems like it is flooding out when I kill it and is way too rich to start. So Far I have checked the following:
- rebuilt carb with pop off at 40psi.
- bought a new OEM mikuni stock superjet 650 carb as I was still convinced it was a carb issue.
- swapped CDI
- checked stator resistance
- compression is 150
- checked reeds
- checked spark.. seems good even when it doesn’t want to start
- new plugs
- check the fuel tank vent
- went really lean on the low screw which helped the restart but creates a hesitation on acceleration
- have a primer installed and when it doesn’t like to start, if I give it a pump it is way worse so this is why I am thinking it is too rich to start.
- stock engine as far as I can see and stock air box.
I haven’t check for an air leak, it seems complicated to do in place, but that might be my next step if I can’t find anything else wrong.
Really appreciate any suggestions....
- swapped CDI
- checked reeds
- new plugs
