Custom/Hybrid superfreaks
Buckwild12
I'm moved by DASA power!
The pros: -super light weight, makes even rather stock motors seem way bigger.- durable, they take whatever you can dish out.- they are very stable at both low and high speeds.- they turn ridiculously quick.- they have a good bit of nose rocker, which greatly resists pearling when riding in the surf.- the tray is huge, and lower in the hull which gives you a lower center of gravity and allows you to ride more comfortably than any other hull I have ridden.- Tem stands behind his work and is a real innovator in this sport.The cons: -they are a bitch to turf.-they will make you think you can land tricks you never thought you should attempt. - it makes you mad when the paint gets scratched. - when I got mine the waiting period was 12-14 weeks for the build, which seemed to take years.I'm sorry if the con list is short I tried, but there really aren't any cons as far as I'm concerned. Mine is the best money I have ever spent on a hobby. My enjoyment of the sport has doubled since the purchase.
it helps the ski right it self faster. worthwhile option. but you need to ride your ski first to make sure you know exactly how long you want the pole.
Buckwild12
Matt-E has one of the carbon poles, but most of the guys that I know of either have the RRP setup or the X-metal adjustable. I personally have the X-metal.
