Mouthfulloflake
ISJWTA member #2
- NW Arkansas
well?
have you taken this long of a break?
Actually, I did. I had a well pump take a crap on me so I diverted my attention to it and yard work. I'll try today and post up.well?
Alright, I just changed the stator again, this time with a known good one from a running motor. I'm getting the same thing. It wants to start so bad. It sputters and every now and then if I feather the throttle, it will backfire so what am I left to do?
Is it possible my crank is not indexed causing the timing to be off so far that regardless of where the stator is set, the timing is off? What's the easiest way to verify indexing/proper crank position?
There's rings on the pistons. I had 150/152 compression at one time. My guess is once it started, I blew a crank seal. From the looks, the rear and front look good but only disassembly of the case and crank will tell me for sure. Anything else it could be considering compression dropped in both at the same time? I wish I had rechecked compression earlier.![]()
Was speaking with Derm here locally. He doesn't think it's a crank seal either. He's thinking its the head gasket and I'm getting crossover between the cylinders. I checked the ports and brought the pistons to TDC and have next to no slop and the pistons recenter themselves as they should. I also checked the head for warpage and it's straight.
I'm in the process of prepping the gasket mating surfaces now. I'll lightly coat the cylinders and drop a new head gasket on and recheck compression.
you should sell it to me for dirt cheap, Ill fix it.
:Banane01:
