Super Jet Supejet 701 w/ coffman sizzler pipe jetting ?
Would love some imput on my jetting which I can't seem to get dialed in. I have an 02 superjet with stock dual carbs with a sizzler pipe on it. Right now everything in the carbs are stock except for a 140 high speed jet. I am running a little rich down low to mid throttle and scary lean at 3/4 to wide open. I am going to try 145 jets to richen up the top end. I have used the low and high speed adjuster and cannot fix the problem. Any suggestions?
Nampa, Id
I have the same question but have a stock 95 FX1 with a single 44 what jets do I need if any? I am getting mixed answers from my research! Some say leave it be others have various answers.
CA
I have stock dual carbs on a ported 701 with a sizzler and i used the recommended b-pipe jetting. Seems to work great for me!
Poizen
Mical
South Africa
I have a sizzler and run on my dual carbs
135 main 1 turn out
75pilot 1.5 turns out
95gram spring
As suggested by jet maniac it works 100% I can go alil leaner but. I rather run a tad rich
