Re-did my '90 SN SJ this winter. bumped up compression, ww cone, etc.
Now when I do tail stands, it sucks air and cavitates.
Actually it sucks air unless the boat is flat on top of the water
I did remove and reinstall grate and plate.
siliconed the plate but not the grate as there was no silicon on it to start with.
Should I pull the grate and try to silicon it back
or should I just get a new pump seal and install and then seal back the grate?
thanks!
thanks!
