stupid throttle cable question
Speleopower
got a Superjet
Cocoa Beach
I'm changing the stock throttle trigger to a UMI throttle trigger. I've been messing the dang throttle cable for about 30 minutes now and I can't get the end loose from the stock throttle trigger.
What's the trick to getting the little barrel end of the cable out of the stock trigger?????? I'm stumped. There must be a trick to it 'cause the cable is in there so it's gotta come out!!!!!
I'm almost at the point that I'm just going to cut it out.
Thanks-Scott
Speleopower
got a Superjet
Cocoa Beach
Got it. It is a "click" in fit. I had to dig in my tools for some thin needle nose pliers to get a grip on it. I figured if I break it no big deal cause I'm going to use the UMI throttle trigger from here on out.
Scott
amemoryoncelost
X2/SNsj
tacoma, wa
I just went to look at mine since mine is still stock. Should be able to use a pair of needle nose or even a screw driver to knock it out. Here is a picture I took with my phone while I was out there, sorry for the quality...
damn, bet me to it, heh. If you decide the UMI throttle isn't right for you, I'll take it off your hands, hah.
