chrisdoc0608
insulting
- rocky mount, nc
here are the symptoms:
90 sj
Motor doesnt crank when start button is pressed, when relay is crossed over with a screw driver or starter is connected directly to battery it cranks fine. I have two relays, neither make a difference, each were tested on a battery for continuity ( red to pos, black to neg and continuity bt the posts was good)
The start/stop switch has excellent continuity on each circuit, as well as both circuits going into the electrical box.
My flywheel key sheared when my splines went a couple weeks ago, my stator now has 0 resistance on two of the coils.
The fuse in the box is good....
Am i overlooking something? i dont think it is necessary for the stator to be good for the motor to turn over... i need some guidance asap.
thanks in advance
90 sj
thanks in advance
