Stripped inserts on pole pad? No problemo
WAB
salty nuts
coastal GA
Pole pad mod
Threaded inserts ripped out so I used 2 pieces of alum strip bent into U shapes to cover where the inserts were. Drilled small pilot holes in the plastic pole pad shell to attach the alum pieces. Drilled & tapped bottom of alum pieces for screws to hold it on.
Also drilled and tapped 1 hole in from of pole to hold down the front of the pole pad.
WAB
salty nuts
coastal GA
I did this pole pad mod months ago.
True, it won't keep my ski from backfiring and blowing the coupler off. :banghead: I don't know what caused it to backfire like that, even after I ran it for a minute before putting it in the water. I wonder if a 2stroke backfire is caused by a lean or rich condtion??
:eek:fftopic:
:eek:fftopic:
bills says no.....
my square used to backfire all the time when I had a leak in my ex chamber.....
