Super Jet stock water routing
ok guy i searched an all i could find was water line routing for non stock exhaust pipes. im putting the motor back in my 200 superjet (bone stock) and cant figure out which way the water lines go i have one line coming from the pisser and i it Just Ts off and i have one line from the pump area that has my flush hook up in it. does this one go to the head or the bottom of the pipe? tell me the routing for one of the hoses and i can figure out the other thanks.
munki63
Epoxy is my duct tape
Canada
I believe your cooling line should go in the bottom and out the top, from the pump-->motor-->pipe-->pisser, you can tee in the flush kit anywhere
fl
the top one from the head to t.
the middle one to the pisser.
the bottom one from pipe to t.
and all the way on the bottom of the manifold goes to pump hose.
and the little hose from head to pipe not in pic
