FX-1 stock twin carbs
Does anyone know if stock SJ twin carbs with stock manifold will fit my
94 fx1. Im not sure off of what year SJ they are off of but Im assuming they are off 62T cases.
Thxs for all imputs
Scott
At the very least, you need an aftermarket dual intake manifold.
Further, the 38mm carbs that Yamaha uses in a dual configuration have their bases at an angle. So you may need a manifold specifically for dual 38s or an adapter plate.
I would call any good builder up on the phone and ask.
Why are you wanting to put dual 38s on that engine?
A single carb is said to be best for those cases.
gorilla
There's Always A Light At The End Of The Tunnel !!
Lost Wages NV
there's a 701 46mm wetjet intake manifold and matching 46mm carb on ebay right now.
that's one way to upgrade your fx1 !!!
i got that setup on my fx1, and it made a big improvement over the stock carb setup !!!
good luck
gorilla
wayne
wannaroll
Mesquite, Texas
or have your mani and carb bored to a 46mm. there are plenty of people that have done this. i think sfl has two done. might be wrong, but i though he posted that once before.
