Super Jet Stock Trigger on X-metal Bars?
Will my Stock Superjet finger throttle fit on my xmetal straight bars? I see no reason why it wouldn't. Both the straight and stock bars are 7/8".
I intend to buy a billet trigger, but money is TIGHT right now and for the rest of the season I will rock the stocker if it will work.
Any thoughts?
It will work, there is just no hole for the screw in the throttle to thread into...you can either drill a hole or thread a slightly larger bolt in the hole in the trigger and use it as a set screw, just don;t over tightrn it or the plastic on the throttle housing will strip out. I used a bolt as a set screw and it worked great.
